  3. Export DXF.
  • Replies 28
  • Subscribers 166
  • Views 32847
Export DXF.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I don't  know how to export DXF for all the present layer by once itself  by using  File->Export->DXF we only take the present layer.  For another we need to change that layer and once again i want to do the same process in this case how to take all the layer by once itself  any one guide me please. if it possible by skill share me the code please.
  • Gowtham229
    Gowtham229 over 7 years ago in reply to vimaldevlpr
    i'll try for skill code of this but generally generating artwork & converting artwork to dxf in cam350/other tool is better
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to Gowtham229
    Thanks a lot  gowtham
  • B Bruekers
    B Bruekers over 7 years ago in reply to vimaldevlpr
    Basically you need to write a conversion file for each film. Then run the a2dxf command line utility to create a dxf.
    Something like this:
        l_cnvFiles = nil
        designName = axlCurrentDesign()
        foreach(filmName axlGetParam("artwork")->groupMembers
            f = strcat("DXF_" filmName)
            p = axlDMOpenFile("ALLEGRO_CNV" f "w")
            fprintf(p "#This is the Layer Conversion File used for\n")
            fprintf(p "#importing DXF data into Allegro/APD.\n\n")
            fprintf(p "#CLASS!SUBCLASS!DXF_LAYER!\n\n")
            foreach(layer axlGetParam(strcat("artwork:" filmName))->groupMembers
                layerStr = parseString(layer "/")
                fprintf(p "%s!\n%s!%s!\n\n" car(layerStr) cadr(layerStr) strcat(car(layerStr) "_" cadr(layerStr)))
            fprintf(p "#END\n")
            push(get_filename(p) l_cnvFiles)
            axlDMClose(p)
            sprintf(cmd "a2dxf -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" f getWorkingDir() designName filmName)
            axlRunBatchDBProgram("Creating DXF File" cmd ?warnProgram t ?noExitMsgs t)
        errset(mapcar('deleteFile l_cnvFiles) t)
    Take a look at the help of 'a2dxf' for the possible command line options.
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to B Bruekers
    Thanks a lott
  • vimaldevlpr
    Hai Bruekers DXF export is perfectly  working As like that any way  to Export  .PDF file Please guide me
