  3. Export DXF.
  • Replies 28
  • Subscribers 166
  • Views 32853
Export DXF.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I don't  know how to export DXF for all the present layer by once itself  by using  File->Export->DXF we only take the present layer.  For another we need to change that layer and once again i want to do the same process in this case how to take all the layer by once itself  any one guide me please. if it possible by skill share me the code please.
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to B Bruekers
    Is there a way to get .pdf file as like this using skill code if it possible please share me the code
  • Gowtham229
    Gowtham229 over 7 years ago in reply to vimaldevlpr
    Hi vimal,
    skill is not required for art to pdf. you can use file->export->pdf which will export all artwork to a single/multiple page pdf as per your selection.if that option is not working you need to install intelligent pdf extension to make it work or install latest hotfix of your tool
    Gowtham
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to Gowtham229
    Thank you
  • Sivaji Chowdary
    Sivaji Chowdary over 7 years ago in reply to vimaldevlpr
    Hi Vimal,
    As I am new and little confused, can you please share the full Skillcode and the way to execute it?
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to Sivaji Chowdary
    Hi Sivaji,
    Actually that is a full code add function thats enougth to execute DXF file ok i too attach the code below.
    DXF.il
     procedure( DXF()
     l_cnvFiles = nil
        designName = axlCurrentDesign()
        foreach(filmName axlGetParam("artwork")->groupMembers
            f = strcat("DXF_" filmName)
            p = axlDMOpenFile("ALLEGRO_CNV" f "w")
            fprintf(p "#This is the Layer Conversion File used for\n")
            fprintf(p "#importing DXF data into Allegro/APD.\n\n")
            fprintf(p "#CLASS!SUBCLASS!DXF_LAYER!\n\n")
            foreach(layer axlGetParam(strcat("artwork:" filmName))->groupMembers
                layerStr = parseString(layer "/")
                fprintf(p "%s!\n%s!%s!\n\n" car(layerStr) cadr(layerStr) strcat(car(layerStr) "_" cadr(layerStr)))
            fprintf(p "#END\n")
            push(get_filename(p) l_cnvFiles)
            axlDMClose(p)
            sprintf(cmd "a2dxf -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" f getWorkingDir() designName filmName)
            axlRunBatchDBProgram("Creating DXF File" cmd ?warnProgram t ?noExitMsgs t)
        errset(mapcar('deleteFile l_cnvFiles) t)
    axlCmdRegister("DXF" 'DXF)
    To execute this file:
    Place the .il file in .brd file location.
    Then in allegro tool use command mentioned below.
    1. In CIW Command
    2. load("DXF.il")
    3. DXF()
