  3. Export DXF.
  • Replies 28
  • Subscribers 166
  • Views 32860
Export DXF.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I don't  know how to export DXF for all the present layer by once itself  by using  File->Export->DXF we only take the present layer.  For another we need to change that layer and once again i want to do the same process in this case how to take all the layer by once itself  any one guide me please. if it possible by skill share me the code please.
  • Sivaji Chowdary
    Sivaji Chowdary over 7 years ago in reply to vimaldevlpr
    Thank you Vimal.
  • AS202407274910
    AS202407274910 over 2 years ago in reply to vimaldevlpr
    Can anyone please help me with the conversion file to export dxf in one go. As I am new to cadence and have no knowledge of this. Please help me with above and guide me. thankyou.
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to AS202407274910
    the  text shown below is an Allegro script that will output all layer to a dxf file
    In allegro enter the command: replay dxf_out_all.scr
    # dxf_out_all.scr
    generaledit
    color192
    generaledit
    QtSignal CVDLayerContainer CVDVisibilityOn clicked
    QtSignal ColorVisibilityDialog CVDOkButton clicked
    dxf out
    setwindow form.dxf_out
    FORM dxf_out dxffile all
    FORM dxf_out dxfformat 'Revision 14'
    FORM dxf_out units INCHES
    FORM dxf_out accuracy 3
    FORM dxf_out accuracy 4
    FORM dxf_out edit
    setwindow form.dxfOutMapping
    FORM dxfOutMapping selectall YES
    FORM dxfOutMapping usedefaultlayernames YES
    FORM dxfOutMapping map
    FORM dxfOutMapping done
    fillin yes
    setwindow pcb
    updateport CVPane
    FORM dxf_out exportsymbols YES
    FORM dxf_out exportpadstacks YES
    FORM dxf_out drillinfo YES
    FORM dxf_out execute
    FORM dxf_out close
    setwindow pcb
    generaledit
    # end of file
  • AS202407274910
    AS202407274910 over 2 years ago in reply to DavidJHutchins
    generaledit
  • DavidJHutchins
    The 'DXF.il' code posted by vimaldevlpr 5 years ago should do what you want...
