  3. Export DXF.
  • Replies 28
  • Subscribers 166
  • Views 32864
Export DXF.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I don't  know how to export DXF for all the present layer by once itself  by using  File->Export->DXF we only take the present layer.  For another we need to change that layer and once again i want to do the same process in this case how to take all the layer by once itself  any one guide me please. if it possible by skill share me the code please.
  • Daniel
    Daniel over 2 years ago in reply to DavidJHutchins
    could you please help a code for import all DXF file into another board a quickly?
    thanks
  • AS202407274910
    AS202407274910 over 2 years ago in reply to DavidJHutchins
    dxf.il
    • Vote Up -1 Vote Down
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to AS202407274910
    Save the following skill code into the file 'DXF.il'
    procedure( DXF()
      let((l_cnvFiles DesignName f p LayerStr cmd)
        l_cnvFiles = nil
        designName = axlCurrentDesign()
        foreach(filmName axlGetParam("artwork")->groupMembers
            f = strcat("DXF_" filmName)
            p = axlDMOpenFile("ALLEGRO_CNV" f "w")
            fprintf(p "#This is the Layer Conversion File used for\n")
            fprintf(p "#importing DXF data into Allegro/APD.\n\n")
            fprintf(p "#CLASS!SUBCLASS!DXF_LAYER!\n\n")
            foreach(layer axlGetParam(strcat("artwork:" filmName))->groupMembers
                layerStr = parseString(layer "/")
                fprintf(p "%s!\n%s!%s!\n\n" car(layerStr) cadr(layerStr) strcat(car(layerStr) "_" cadr(layerStr)))
            fprintf(p "#END\n")
            push(get_filename(p) l_cnvFiles)
            axlDMClose(p)
            sprintf(cmd "a2dxf -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" f getWorkingDir() designName filmName)
            axlRunBatchDBProgram("Creating DXF File" cmd ?warnProgram t ?noExitMsgs t)
        errset(mapcar('deleteFile l_cnvFiles) t)
    axlCmdRegister("DXF" 'DXF)
    then in Allegro at the 'command>' prompt enter the following:
    skill load 'DXF.il'
    DXF
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to DavidJHutchins
    Opps, change the the registered command name from 'DXF' to 'ART_DXF' as it breaks the original 'dxf in' and 'dxf out' commands
  • AS202407274910
    dxf_in, dxf_out
