  3. Export DXF.
  • Replies 28
  • Subscribers 166
  • Views 32872
Export DXF.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I don't  know how to export DXF for all the present layer by once itself  by using  File->Export->DXF we only take the present layer.  For another we need to change that layer and once again i want to do the same process in this case how to take all the layer by once itself  any one guide me please. if it possible by skill share me the code please.
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to AS202407274910
    I used the wrong quote in the skill load statement, please replace it with:
    skill load "DXF.il"
    s
  • AS202407274910
    AS202407274910 over 2 years ago in reply to DavidJHutchins
    skill load "DXF.il"
  • DavidJHutchins
    I made a simple change to the skill code to write the dxf files to the outputs folder:
    C:\Temp>diff dxf.bak dxf.il
    18c18,19
    < sprintf(cmd "a2dxf -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" f getWorkingDir() designName filmName)
    > createDir("outputs")
    > sprintf(cmd "a2dxf -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/outputs/%s_%s.dxf\" %%s" f getWorkingDir() designName filmName)
