  3. bottom symbol Pin number not visible in auto cad while exporting...
  • Views 16713
bottom symbol Pin number not visible in auto cad while exporting DXF file from allegro ??
kabalee
kabalee over 6 years ago
Hi everyone,
i tried to export  the bottom pad pin number from allegro as DXF file. while import i could not find the Bottom pad pin number in auto cad. i could see the TOP pad pin number in auto cad.
but i could not visible bottom pad or bottom symbol pin number in auto cad. is any special setting is there in allegro ??
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I just tested this in SPB 16.6 & I can see the pin text for both the top and bottom pins, however the text is all on 1 layer in both Allegro & the DXF file
    The difference in the DXF data is the "Generation:  Normal" vs "Generation:  Backward" information which reflects the text mirror status for top vs bottom
  • kabalee
    kabalee over 6 years ago in reply to DavidJHutchins
    I am using 17.2 version even though I could not see the bottom pad pin number. can help for this
  • kabalee
    kabalee over 6 years ago in reply to kabalee
    Kindly reply for this post.. i could not see the bottom pad pin number. i am using 17.2 version
  • Lock2002
    Lock2002 over 5 years ago in reply to DavidJHutchins
    I know this is an old post, but how did you get pin numbers for bottom pads to export? It will export pin numbers for top pins, but not bottom pins for me (all SMT). Using 17.4
