  3. Bus routing in Allegro PCB Designer
  • Subscribers 166
  • Views 18828
dontknowwhy
dontknowwhy over 6 years ago
Hello, i am a student studying allegro pcb designer.
I have trouble in routing a bus. I think all of channels in a "bus" must have same( or very similar) characteristics so that they must be routed in a same topology (very close paths).
I just realized the way how to make a bus and add channels in the bus. However, i can't route them together simultaneously.
I want to know the exact meaning of "bus" and how to route a bus simultaneously.
Thank you for reading a long boring question, and i am waiting for a valuable answer.
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    BUS is a collection of nets. Cadence PCB tools have made PCB routing very easy over the years. select the group of nets - add connect and you can route them (it is called group routing)
  • RFinley
    RFinley over 6 years ago +1
    The drawback of routing a bus together is an increase in capacitive noise coupling between adjacent nets if your net-to-net clearance is too small. But, it is also important to avoid unnecessary via transitions…
  • RFinley
    RFinley over 6 years ago in reply to dontknowwhy +1
    When you launch Allegro, which license options do you see? I work for a company that focuses on RF boards. I can't justify the cost of the AIDT option when we don't use DDR or PCI-E parts. https://www…
  • AvengerThanos
  • RFinley
    The drawback of routing a bus together is an increase in capacitive noise coupling between adjacent nets if your net-to-net clearance is too small.  But, it is also important to avoid unnecessary via transitions to minimize SI problems.  (not minimizing return current/loop area size and poking holes in your power/gnd planes can impact SI performance.)
    .Allegro has a Floorplanning option in the base license with auto-interactive routing as an (expensive) option.   I use the included floorplan routing on available signal layers to guess IC spacing but manually route the nets.
    https://www.youtube.com/results?search_query=alllegro+flow+planning
    Have to say I'm delighted you're picking up allegro and not the kiddie-pool tools like Altium or PADS.
  • dontknowwhy
    dontknowwhy over 6 years ago in reply to AvengerThanos
    Oh, thanks for reply. It is useful for me.
    On the other hand, does "bus" mean just a collection of nets? Just selecting the group of nets and connect them with function "add connect" has nothing to do with "bus".
    I want to know if there are more functions that can be done with "bus".
    Thanks a lot again and i will be waiting for reply.
  • dontknowwhy
    dontknowwhy over 6 years ago in reply to RFinley
    Thanks for reply.
    I watched some youtubes and there were many helpful videos.
    However, i have a question about your reply. Doesn't Allegro tool have a auto-routing function? Why do you route manually? not using this option?
    Thanks a lot again and i will be waiting for your reply.
  • RFinley
    https://www.youtube.com/watch?v=yoxqYej1KBs
