  3. Import footprint PCB
  • Replies 11
  • Subscribers 166
  • Views 23148
Bellido98
Bellido98 over 6 years ago
How can I import a footprint into OrCAD PCB Designer Professional?.
I download the file from any provider and run the .bat file
with the following problem appearing: Cannot open script file; No match found for 'footprint.scr' in the search path.
  • Bellido98
    Bellido98 over 6 years ago in reply to CadAce2K
    No file with psm extension appears in the downloaded file. There are only files with edf and scr extensions, in addition to .bat
  • excellon1
    excellon1 over 6 years ago in reply to Bellido98
    Hi if you can attach the zip file I can take a look. In the mean time from your post this sounds similar to how other component builders for allegro work. Give the following a try.
    In order for Allegro to know how to execute a .scr script file outside of the allegro environment Allegro has to know where the script files are.
    1 Create a folder on your drive, I use C:\my-parts and put the unzipped files in it.
    2 Go into allegro and open User Preferences editor. In the search box put in   scripath   and hit the search button
    3 You will see a button for the scripath, click on it and add your path to those file in.. Example C:\my-parts
    4 Click ok to get out of that window, close out the editor and exit allegro.
    5 In your folder click on the bat file. Usually the bat file will launch Allegro and then execute that .SCR file which is used to build your part and padstacks.
    If all goes good in the folder C:\my-parts you should see a directory with the newly created part name. Your Symbol for Allegro will be in it.
    Maybe that will help ?
    Thanks.
  • Bellido98
    Bellido98 over 6 years ago in reply to excellon1
    Thanks for your contribution. I have solved the problem in another way.
  • CadAce2K
    CadAce2K over 6 years ago in reply to Bellido98
    Quite strange - so I 'registered' to the site; set my SW tool preferences in my Profile; installed the downloader; and downloaded my first part (TLV320AIC3100IRHBR, TI part). When I hit the DOWNLOAD tab it saved a .zip file to my computer. When I look in the zip file there are multiple folders, and I looked in the Allegro folder. The .psm and .pad files were there for loading the footprint. There's no conversion necessary. Bam! Done!  The Orcad folder had an .XML file in it, but you're interested in the footprints, so I don't care about it. But the site has the parts, and you can download to your delight - assuming the part is in their library. Good day.
  • AvengerThanos
    AvengerThanos over 6 years ago
    You don't need to perform all the below steps. The latest Cadence 17.4 has the Samacsys component search engine interfaced with it. In schematics Place - Search providers will direct you to samacsys site for downloading schematic, footprint and 3D models if available. Hope this helps
