  3. Text line is outside of the extents
  • Replies 11
  • Views 28092
EuSV
EuSV over 6 years ago
Can anybody explain what does it means this msg error?
When I update the PCB this happens:
" Netrev error detected. ERROR(SPMHDB-195): Error processing 'U8': Text line is outside of the extents.."
 Is it about footprint drawing (text)? or is it about text inside some file, other text issues, etc?
Thanks in advance.
  • RFinley
    RFinley over 6 years ago +1
    For me this happens when the part attribute on a part is changed to something too long to fit in the default extents (not the board outline, the size of the design area). menu button. >Quick Utilities…
  • steve
    steve over 6 years ago in reply to CadAce2K +1
    The size of the extents will impact the size of the database so if you make this too large the file size will increase.
  • steve
    steve over 6 years ago in reply to EuSV +1
    So try increasing the Height then decrease the lower Y....You may want to set the Width and Height to a larger value (say 1000) just for now until you can import the design. You can always reduce it later…
  • RFinley
    menu button.   >Quick Utilities >Design Paramters > [Design Tab]  [Extents]
    The default extents in MM tend to be rather small.
  • EuSV
    EuSV over 6 years ago in reply to RFinley
    I have translated an old version project and update it to 16.6. I have not created the footprints. I'm so new with OrCad yet. But I could feel the differences managing OrCad versus other PCB CADs, as Eagle or Altium.
    Thank you so much for your answer, I have followed the steeps you share here, I have this right now:
    I don't know what ot the 3 texts blocks is the one that is going out of the extents.
    What is supposed that I must do with the extents parameter? Can I make it bigger? Must I edit some text value nam and do it smaller?
    I don't know how to edit the text and change names, or how to know in what layer is everyone, there is no right click menu on the footprint to display this information. It seems to be a little more complex.
    Thanks in advance.
  • CadAce2K
    CadAce2K over 6 years ago in reply to EuSV
    Hi Eu. In the footprint editor you're ok. Everything fits in the 38x38mm Extents. What you need to look at is the board file you're trying to bring this into. If your design Extents are say 100x100mm you'll have no problems bringing this footprint in, as long as you don't shove it over into some corner of your board. If you do have that issue, just increase the board file's Extents (say to 200x200mm).
  • CadAce2K
    CadAce2K over 6 years ago in reply to CadAce2K
    And there's nothing special about the board file Extents. You can make it as large as you want. Do a 'window world' and you'll see the board size vs the Extents.
  • RFinley
    RFinley over 6 years ago in reply to CadAce2K
    always wondered if it was a "fence" to make sure we don't accidentally zap something 12 feet away from the origin or if it impacted the database size for the board.
