  3. Text line is outside of the extents
  • Replies 11
  • Views 28093
EuSV
EuSV over 6 years ago
Can anybody explain what does it means this msg error?
When I update the PCB this happens:
" Netrev error detected. ERROR(SPMHDB-195): Error processing 'U8': Text line is outside of the extents.."
 Is it about footprint drawing (text)? or is it about text inside some file, other text issues, etc?
Thanks in advance.
  • RFinley
    RFinley over 6 years ago +1
    For me this happens when the part attribute on a part is changed to something too long to fit in the default extents (not the board outline, the size of the design area). menu button. >Quick Utilities…
  • steve
    steve over 6 years ago in reply to CadAce2K +1
    The size of the extents will impact the size of the database so if you make this too large the file size will increase.
  • steve
    steve over 6 years ago in reply to EuSV +1
    So try increasing the Height then decrease the lower Y....You may want to set the Width and Height to a larger value (say 1000) just for now until you can import the design. You can always reduce it later…
  • steve
  • EuSV
    EuSV over 6 years ago in reply to CadAce2K
    Hello!
    A lot of thanks CadAce!
    But the board file is not created yet, due to the extent error that I wrote before. I'm updating board from create netilist in cadence with the create or update PCB editor board option. Then input file option I put the original file and output I put the name of a new board in order to create a new version file and let the old version there.
    1.- Must I change the original board file extent?
    2.- I'm unable to see what is the text block that is out of extents, any suggestion for knowing what is it and how to solve that, without changing extent value?
    3.- How can I do a "hello window"? what do you mean with this?
  • steve
    Yes open the original board file and increase the design extents (Setup - Design Parameters - Design tab) better to increase the lower portion so set a left x and lower y to say -100 -100 (mm) and see if that helps.
  • EuSV
    EuSV over 6 years ago in reply to steve
    ouch, I can't change the extent y parameter. It' said "can't reduce upper y extent":
    After click "ok" it does not happen any change. It stills -77 value.
  • steve
    So try increasing the Height then decrease the lower Y....You may want to set the Width and Height to a larger value (say 1000) just for now until you can import the design. You can always reduce it later.
