  3. Text line is outside of the extents
  • Replies 11
  • Views 28096
EuSV
EuSV over 6 years ago
Can anybody explain what does it means this msg error?
When I update the PCB this happens:
" Netrev error detected. ERROR(SPMHDB-195): Error processing 'U8': Text line is outside of the extents.."
 Is it about footprint drawing (text)? or is it about text inside some file, other text issues, etc?
Thanks in advance.
  • RFinley
    RFinley over 6 years ago +1
    For me this happens when the part attribute on a part is changed to something too long to fit in the default extents (not the board outline, the size of the design area). menu button. >Quick Utilities…
  • steve
    steve over 6 years ago in reply to CadAce2K +1
    The size of the extents will impact the size of the database so if you make this too large the file size will increase.
  • steve
    steve over 6 years ago in reply to EuSV +1
    So try increasing the Height then decrease the lower Y....You may want to set the Width and Height to a larger value (say 1000) just for now until you can import the design. You can always reduce it later…
  • EuSV
    EuSV over 6 years ago in reply to steve
    Great! lot of thanks! it works!
