  3. Unrouted net
  • Views 16610
Unrouted net
KobiC
KobiC over 6 years ago
Among the components in my layout, I have a transformer and an electrolytic capacitor (see picture).
All the nets are routed, except this one. I've tried to think about everything - but for some reason, Allegro insist to keep them unrouted.
In layer #2 (Power), colored in yellow, there is a shape that covers them both, incluting thermal releif. It seems that they must be routed: both pins and shape in the same net name.
I have also checked the padstack of those 2 pins - both are defined well to all the layers.
At the top layer (green), the transformer pin also connected to SMT capacitors - very well.
What do you think?
  • steve
    steve over 6 years ago
    Try a Database Check first and see if that help. I'd also check all the connections on the net to make sure somewhere else on the board isn't missing a connection. If that doesn't help the padstacks and vias need to checked to make sure they are plated through holes and have pads on the relevant layers.
  • KobiC
    KobiC over 6 years ago in reply to steve
    Hi Steve, thanks :) how do you run database check?
  • steve
    steve over 6 years ago in reply to KobiC
    Allegro Tools - Database Check, OrCAD Check - Database Check, check all the options and click on Check, then once complete look at viewlog.
  • KobiC
    Thanks Steve! the problem was found: there was a small difference between the FP at the scheme and the padstack name.
