  3. How to handle "unconnected pins" when they are apparently...
  • Replies 8
  • Subscribers 167
  • Views 13134
How to handle "unconnected pins" when they are apparently connected throught copper tracks?
EuSV
EuSV over 6 years ago
I have done a translation from old project to 16.6 orcad version. I have followed the whole of files traslation steps, importation, configurations, etc until I had no errors. I generated netlist and update the board layout. So looking to the pcb editor canvas it can be seen that there are some rastnets between pins that are connected because they have tracks connections. I followed the tracks, vias, etc path and there are electrical path. So I don't know how to solve this.
example:
So I generated the unconnected pin report and this says that there is unconnected some of them, including the one seen at picture. I check the track names and all the segments forming the track path has the same net name.
How can I deal with this? How can I do for looking the part that is not connected? can it be an interface mistake? I'm sure that the two pins has connection has a continuous track connection.
  • steve
    steve over 6 years ago in reply to EuSV +1
    Check the Options Pane once you have selected Route - Connect, there is a Bubble mode, if this is set to None then you can create DRC errors, try Shove Preferred (to shove other objects out of the way…
  • steve
    The Menu Route > Connect then look at the Options fold out pane on the hand side of the screen (in 16.6 hover over the Options fold put panel).
  • excellon1
    excellon1 over 6 years ago +1
    Eusv a couple of pointers. As Steve has pointed out Cadence handles a little differently how pins, vias, etch is connected. To make things easier it can be helpful to have a clearer look at the canvas…
  • steve
    So some other CAD packages don't care about pin origins whereas the Cadence PCB Tools do and the tracks do not connect to the origins of the pads. Try running Tools - Derive Connectivity, enable some pf the options and see if that helps, if it doesn't try some of the other options.
  • EuSV
    EuSV over 6 years ago in reply to steve
    My old project was created with an old version of Cadence/Orcad. I'm new with it, and now I'm trying to repaint these tracks. I deleted the tracks (supposedly unconnected ones) and I'm trying to paint the same tracks but it's impossible with Allegro's. I don't know what happens I can't believe it would be so problematic. I click on "add connect" icon and then I click first pad and then second point. But I can't modify the path that CAD is forcing, it paints the track where it wants, making contact with other tracks belonging to other nets, making a mess. Why I'm not able to paint the track by the way that I want?
     This is taking 2 days of work for me and I have not done any track/net change yet. I don't know what I can do.
    Thanks steve.
  • masamasa
    masamasa over 6 years ago
    i find that the "unconnected pins report" does not indicate the locations where the nets are unconnected.
    so it is very frustrating.
    it is very difficult to find the unconnected point just by looking at the report.
    what i usually do in this situation is to find antenna vias on the "dangling line, via and antenna report" and remove or modify those antenna vias one by one.
    most of the time it works for me to clear the unconnected pin issue.
  • steve
    Check the Options Pane once you have selected Route - Connect, there is a Bubble mode, if this is set to None then you can create DRC errors, try Shove Preferred (to shove other objects out of the way) or Hug Only to Hug items, Check your Grid settings under Setup - Grids to make sure that the Etch Grids are realistic, you can also (once you have selected a ratnest) right click - and uncheck Enhanced Pad Entry which might give you more control about where the route is going, sometimes if you are routing to a pin this controls how a route enters the pin without making manufacturing issues.
  • EuSV
    what is route - connect in options panel? I don't see that. I'm working with 16.6 version.
    Thanks!
