  3. Creo Parametric 3.0
  • Subscribers 166
  • Views 17718
Creo Parametric 3.0
Lock2002
Lock2002 over 6 years ago
Has anyone seen copper artwork successfully imported in Creo Parametric? I've seen it done in a Youtube video, so I know it's possible. I've created an .eda file using Creo View, but all we were able to import is vias. We do have the ECAD/MCAD collaboration license.
  • redwire
    redwire over 6 years ago
    Hmmm....are you exporting a STEP file from Allegro with all copper layers on?  This should work.  Be sure to enable "step_3d_copper" which is a setting in the user preferences.
    Post back if it still doesn't work as there are some other ways to get the copper in but STEP is the simplest way.
  • RFinley
    RFinley over 6 years ago
    RedWire is right.   A step export from Orcad Allegro should give you copper for thermal simulation.
    But, if you're getting board outlines and placement from EMN/IDF, that has been around since the 90's.
    The IDF interface will only manage board outline/cutouts, mechanical or electrical holes, and component placement.
  • Lock2002
    Lock2002 over 6 years ago in reply to RFinley
    STEP files are huge. It can take hours to pull in depending on the board size and amount of vias.
    This is the video I was referring to. https://www.youtube.com/watch?v=Twy8RkGtcSY
  • RFinley
    RFinley over 6 years ago in reply to Lock2002
    I always give our ME's step files exported from the main Allegro UI.
    Step from the 3D environment, it has a lot of extra detail for some reason.
    File>  Export> Step...>
