  3. Dynamic shape flood spacing
  • Replies 15
  • Views 21256
Lock2002
Lock2002 over 6 years ago
Is there any way to find an resolve issues like this other than visually?
  • steve
    steve over 6 years ago in reply to Lock2002
    OK - Try adjusting your Min aperture for artwork fill (Global Dynamic Params) and see if that stops this type of issue being generated in the first place.
  • RFinley
    RFinley over 6 years ago in reply to Lock2002
    Do they consider this an acid trap?
    I'll shorten my first answer then.
    The new DFM antenna checks in 17.4 seem to work with traces and vias but not dynamic shapes.
  • Lock2002
    Lock2002 over 6 years ago in reply to steve
    I have gap width set to 6 mil. I can change it to 10 mil and that particular one goes away, but others pop up.
  • RFinley
    (oh yeah, Steve mentioned this) There is a setting under Shape> Global Dynamic Shape Parameters> Void Controls tab
    "Minimum aperture for gap width".  Basically manages the smallest aperture used to generate dynamic shapes.
  • stumpsr1019
    stumpsr1019 over 6 years ago in reply to Lock2002
    we have our min aperture set to 3.499 and do all our planes as positives. Might muck with your Acute angle trim control. One thing that I always
    thought that the tool should have is Creating pin voids In-line if you selected a group of pins or vias not for an entire shape. It would be good for BGA's
    and connectors.
