  3. Half filled shape in vias
  • Replies 16
  • Subscribers 166
  • Views 23779
vimaldevlpr
vimaldevlpr over 6 years ago
Is any way to find the location half filled shape in via using skill. if it possible can anyone please share me the code or guide me how to do it.
Like this Red color via
  • luanvn81
    luanvn81 over 6 years ago in reply to vimaldevlpr +1
    Hi Vimaldevlpr! Sorry, try below code please. axlCmdRegister("svc" `svc) (defun svc () originalVisible=axlVisibleGet() designName = axlCurrentDesign() design_path = axlGetDrawingName() design_unit…
  • luanvn81
    Hi! you can try below code for choosing shapes: ;#### SELECT SHAPES TO CHECK #### axlSetFindFilter(?enabled '(noall SHAPES) ?onButtons '(noall SHAPES)) axlClearSelSet() mypopup = axlUIPopupDefine(…
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to luanvn81
    Hai luan One more last Suggestion
    Instead of picking fully wants to check.
    AllShapeCheck = axlGetSelSet(axlSelect(?prompt "Please Select Shape..."))
    AllShapeCheck = axlGetSelSet(axlAddSelectAll())
    like this method
    it shows me E- *Error* lessp: can't handle (nil < 314.1593)
    can you please update it..
  • luanvn81
    Hi!
     I have updated code.
    (defun svc ()
    design_unit = car(axlDBGetDesignUnits())
    View_list = list()
    AllShapeCheck = axlDBGetShapes("ETCH")
    ;AllShapeCheck = setof(element AllShapeCheck element->fillet == nil) ; fillet shape
    ;=====Prepare to check via =====
    if(length(AllShapeCheck)== 0 then
    axlUIConfirm("No shape found!")
    else
    writeOutFile = outfile("./svc.log" "w")
    timeperform = fileTimeModified("svc.log")
    fprintf(writeOutFile, "Design name: %s\n", design_path)
    fprintf(writeOutFile, "%s %s\n\n", "Date: ", timeToString(timeperform))
    fprintf(writeOutFile, "%s\n", "--------------------------------------------------------------------------")
    fprintf(writeOutFile, "%-5s %-10s %-10s %-20s %-22s\n\n", "No", "Layer", "Net Name", "Via Name", "Location")
    STT = 0
    foreach(shape AllShapeCheck
    shape_layer = lastelem(parseString(shape->layer "/"))
    shape_poly = car(axlPolyFromDB(shape))
    axlSetFindFilter(?enabled '(noall VIAS) ?onButtons '(noall VIAS))
    via_list = setof(element axlGetSelSet(axlSingleSelectBox(shape->bBox)) element->net->name == shape->net->name)
    ;via_list = axlDBGetConnect(shape t)
    axlClearSelSet()
    foreach(via via_list
    via_poly = car(axlPolyFromDB(via ?layer shape->layer ?padType "REGULAR"))
    ANDPoly = car(axlPolyOperation(shape_poly via_poly 'AND))
    if(ANDPoly != nil && ANDPoly->area < via_poly->area then
    View_list = cons(sprintf(nil , "%-10s %-10s %-20s %L", shape_layer, via->net->name, via->name, via->xy) View_list)
    );foreach via
    );foreach shape
    View_list = sort(View_list 'alphalessp)
    foreach(item View_list
    STT = STT + 1
    fprintf(writeOutFile,"%-5d %-s\n", STT, item)
    );end foreach
    close(writeOutFile)
    if(STT > 0 then
    axlUIViewFileCreate("svc.log" "Via contact report..." nil);t xoa file sau khi xem, nil khong xoa
    else
    axlUIConfirm( "No Error found.")
    if(isFile("svc.log") == t then deleteFile("svc.log"));end if
    ); end if count_drc
    );end if
    );end defun svc
    Tks
    Luan.
  • vimaldevlpr
    Hi Luan,
    One suggestion please for larger brd files it takes more time to complete can you please update this code for checks  only visible layer in brd file or choosing shapes like temp group method can you please update this code.
  • luanvn81
    Hi!
    axlClearSelSet()
    mypopup = axlUIPopupDefine( nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet( mypopup)
    axlClearSelSet()
    AllShapeCheck = setof(element AllShapeCheck element->fillet == nil) ;ignore fillet shape
    Luan.
  • vimaldevlpr
    Kindly Thanks a lot for your support and help
