  3. Half filled shape in vias
  • Replies 16
  • Subscribers 166
  • Views 23787
vimaldevlpr
vimaldevlpr over 6 years ago
Is any way to find the location half filled shape in via using skill. if it possible can anyone please share me the code or guide me how to do it.
Like this Red color via
  • luanvn81
    luanvn81 over 6 years ago in reply to vimaldevlpr +1
    Hi Vimaldevlpr! Sorry, try below code please. axlCmdRegister("svc" `svc) (defun svc () originalVisible=axlVisibleGet() designName = axlCurrentDesign() design_path = axlGetDrawingName() design_unit…
  • luanvn81
    Hi! you can try below code for choosing shapes: ;#### SELECT SHAPES TO CHECK #### axlSetFindFilter(?enabled '(noall SHAPES) ?onButtons '(noall SHAPES)) axlClearSelSet() mypopup = axlUIPopupDefine(…
  • Parames
    Parames over 1 year ago
    Hi all,
    I have tried this code and its not showing any error, but i have the error that half shape connected in same net via. can someone help me to figure out issue?
    parameswaran
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to Parames
    I updated the code by correcting a few issues to make skill lint happy, added a meter so you can see the progress thru the shapes,
    added the 'ErrorTypes' of 'Coverage' for the original & added 'NoConnect' for same-net vias not connected to the shape...
    the attached zip file contains the alatest skill code...https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/svc.zip
  • Parames
    Parames over 1 year ago in reply to DavidJHutchins
    Hi David,
     This code checks overall shape in my design, but if its multi-layer project it takes too much of time, can you please get the code for layer-by-layer shape check.
    Thanks.
  • DavidJHutchins
    I added a command line option to allow you to specify which layer to process, below are examples from the journal file:
    \i (00:06:15) skill 'load "svc.il"'
       (00:06:15) function svc redefined
       (00:06:15) t
    \i (00:06:18) svc botom
    \t (00:06:18) Layer botom not found
    \i (00:06:18) generaledit
    \i (00:06:38) svc bottom
    \i (00:06:39) setwindow text
    \i (00:06:39) stick
    \i (00:06:39) setwindow pcb
    \i (00:06:39) generaledit
    \i (00:06:55) setwindow text
    \i (00:06:55) close
    the updated code is in the attached zip file
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/1385.svc.zip
  • Parames
    Hi David,
    thanks for the support. i have one more change from this code, i try to fix that but i got error.
    "My requirement is need to find if shape is not covering the drill only", if shape not fully cover the pad i don't have any issue in that. can you please help me to fix.
    Thanks.
