  3. Half filled shape in vias
  • Replies 16
  • Subscribers 166
  • Views 23792
vimaldevlpr
vimaldevlpr over 6 years ago
Is any way to find the location half filled shape in via using skill. if it possible can anyone please share me the code or guide me how to do it.
Like this Red color via
  • luanvn81
    luanvn81 over 6 years ago in reply to vimaldevlpr +1
    Hi Vimaldevlpr! Sorry, try below code please. axlCmdRegister("svc" `svc) (defun svc () originalVisible=axlVisibleGet() designName = axlCurrentDesign() design_path = axlGetDrawingName() design_unit…
  • luanvn81
    Hi! you can try below code for choosing shapes: ;#### SELECT SHAPES TO CHECK #### axlSetFindFilter(?enabled '(noall SHAPES) ?onButtons '(noall SHAPES)) axlClearSelSet() mypopup = axlUIPopupDefine(…
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to Parames
    I added an optional Drill command line switch to change from the pad size to the drill size:
    C:\Users\David1\Documents>diff svc.il~ svc.il
    1c1
    < procedure(svc(@optional (Layer ""))
    > procedure(svc(@optional (Layer "") (Drill nil))
    61c61,65
    <                         (via_poly = car((axlPolyFromDB via ?layer (shape->layer) ?padType "REGULAR")))
    >                         if(Drill then
    >                             (via_poly = car(axlPolyFromDrillHole(via)))
    >                         else
    In my test-case design running the following command found 194 issues:
    \i (00:01:51) svc top
    While the following command found 1 issue:
    \i (00:02:07) svc top t
    The skill code is in the attached zip file
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/4035.svc.zip
