  3. Cant use cadence PCB's auto-router option
  • Replies 8
  • Subscribers 168
  • Views 10351
juanjoc
juanjoc over 6 years ago
Hello everyone. I'm new in cadence products. I wonder if there is a way to solve the following mistake. When I had all the electronic devices placed on the PCB, and I want to route all the tracks but not manually because there are a lot of them, so I try to use the option "Route->PCB router->Route automatically" but cadence throw me a message that disable the "Route" option.
"Please verify that you are running allegro pcb router version V9.0 or later. try "file viewlog" to view  Allegro PCB rpouter's log file"
Thanks in advance.
  • RFinley
    RFinley over 6 years ago
    Which license level are you using?  Orcad or Orcad Professional?  What does it say with "file viewlog"?
  • ichliebedich
    ichliebedich over 6 years ago
    I had same problem before, but I found the cause! when I removed all of Clines and Vias on the board, it works correctly. if there are the clines or vias that I created by hand on the board , it happened kind of that problem in my case. it has some bug I guess....  (I used professional license)
  • UlfK
    UlfK over 6 years ago in reply to ichliebedich
    Last time I used the AutoRouter there was a check-box "Protect Routes/vias". When this is set, only unrouted nets will be handled by the autorouter. An advice is to route all critical nets first such as clock, power, create planes, etc and leave the uncritical nets to the autorouter. If you make a save of the half-way completed board, you can use a copy for experimenting, setting the layer route preferences, cleaning up via options, etc. It was some time since I used it (OrCAD Professional), but I think that constraints created in CM will be honored by the router.
    Even if the routers are quite clever, I have always had to spend some time in a manual optimization of routes afterwards.
  • juanjoc
    juanjoc over 6 years ago in reply to RFinley
    1. I am using Orcad Professional
    2. which viewlog file do you refer? i have like 5 .log files, some of them are like the following
    for example in netlist.log
    { Using PSTWRITER 17.2.0 d001Sep-03-2020 at 08:05:06 }
    #1 WARNING(ORCAP-36006): Part Name "L_DISC_350X175_LS200X100_034_200UH" is renamed to "L_DISC_350X175_LS200X100_034_20".
    #2 WARNING(ORCAP-36006): Part Name "2N7000KL_0_TRANSISTOR2N7000SMD_SOT23_3L_2N7000KL" is renamed to "2N7000KL_0_TRANSISTOR2N7000SMD_".
    INFO(ORCAP-36080): Scanning netlist files ...
    Loading... C:\USERS\PERSONAL\ONEDRIVE\PROYECTOS\pstchip.dat
    Loading... C:\USERS\PERSONAL\ONEDRIVE\PROYECTOS\pstxprt.dat
    Loading... C:\USERS\PERSONAL\ONEDRIVE\PROYECTOS\pstxnet.dat
    packaging the design view...
    In created symbols it says
    (    CREATE SYMBOL                                                    )
    (    Drawing          : resistencia1_16w.dra                          )
    (    Software Version : 17.2P019                                      )
    (    Date/Time        : Thu Aug 27 15:35:04 2020                      )
    Create Symbol of type: PACKAGE
       Directory = C:/Users/Personal/OneDrive/Proyectos/PCB v3 v1
       Name      = resistencia1_16w.psm
       User      = Personal
       Machine   = DESKTOP-T3EOOM5
    Create symbol started.
    Create symbol completed.
      In batch_drc.log it says
    (    DRC Update                                                       )
    (    Drawing          : sym_template.dra                              )
    (    Software Version : 17.2P028                                      )
    (    Date/Time        : Fri Aug 28 13:21:29 2020                      )
    ========= check shapes                       0:00:00
    ========= check standalone pins              0:00:00
    ========= check symbols (pins,lines,text)    0:00:00
    ========= check xnets                        0:00:00
    ========= check nets                         0:00:00
    ========= check standalone branches          0:00:00
    ========= check standalone filled rectangles 0:00:00
    ========= check standalone lines             0:00:00
    ========= check standalone text              0:00:00
    ========= check standalone rectangles        0:00:00
    ..... Total number of DRC errors  0
    ..... DRC update completed, total CPU time   0:00:00
  • juanjoc
    juanjoc over 6 years ago in reply to juanjoc
    When I open first time the pcb file and open the viewlog, it shows me more than one. but when I select ROUTE/PCB ROUTER/ROUTE AUTOMATIC then it show me the error and the view log is only one.
    and the viwelog fle:
    #                               Allegro PCB Router
    # Copyright 1990-2010 Cadence Design Systems, Inc.  All Rights Reserved.
    # Software licensed for sale by Cadence Design Systems, Inc.
    # Current time = Wed Sep 09 11:32:25 2020
    # Allegro PCB Router v17-2-50 made 2016/03/28 at 15:56:36
    # Running on: desktop-t3eoom5, OS Version: WindowsNT 6.2.9200, Architecture: Intel Pentium II, III, or 4
    # <> Unrecognized argument: v17400_0
    # Licensing: The program will not obey any unlicensed rules
    # <> Unrecognized argument: C:/Users/Personal/OneDrive/Proyectos/PCB v3 v1.dsn
    # No graphics will be displayed.
    # Design Name v3\design
    # Batch File Name: pasde.do
    # Startup: File Not Found : v3\design
