  3. push command
  • Views 14283
push command
Ejlersen
Ejlersen over 6 years ago
Hi
In the following post https://community.cadence.com/cadence_technology_forums/f/pcb-skill/45333/paste-mask-openings-only-for-populated-components/1368159#1368159
a command named "push" is used in the part below but I cannot find the documentation for push.
Anyone know what it actually does, I've previously done something similar but without push, so I'm just wondering if there is any advantage in that?
/Ole
push(make_axlPadStackPad(
?layer new_layer
?type concat(pad->type)
?flash pad->flash
?figure if(pad->figureName == "SHAPE", pad->name ,pad->figureName)
?figureSize figureSize
?offset pad->offset
) pad_list)
  • larry briski
    larry briski over 6 years ago
    Google "lisp push command" .     Way to much information for me to process without coffee.
  • Ejlersen
    Ejlersen over 6 years ago in reply to larry briski
    Thanks, you're absolutely right :-)
