  3. Allegro PCB 17.4 is not working despite of other versions...
  • Views 16803
Allegro PCB 17.4 is not working despite of other versions were worked well
ichliebedich
ichliebedich over 6 years ago
Hi all
my license included 17.4 ver.
and it worked well before, but suddenly it was not worked
when I run PCB17.4.exe and selected the license (allegro PCB) then the program started like before pic
and then if I hit the "yes" button, the Allegro PCB Designer is going down
the pic below is being waiting the program working, but it kept that status forever
so there was no choice to close, to escape that states
the IP address and Port worked well, I tested by 17.2 version.
only 17.4 version had that issue
regards
  • RFinley
    RFinley over 6 years ago
    Ok, you have 17.4 and SP11 installed.  That's good.
    Did you do a recent install and did you reboot your machine afterwards?  (trying all the easy fixes first?)
    I would answer "no" to the upgrade dialog from 17.2 to 17.4 question, that cancels the open-most-recent automation.
    Then you should be able to open a different board file..
  • ichliebedich
    ichliebedich over 6 years ago in reply to RFinley
    yeah I did all, I rebooted and reinstalled even I run of Base without Hotfix, but it has same issue
    if I open the app with default, it has same issue as well
    it seems like kind of OS issue with SPB 17.4 in my computer
  • RFinley
    RFinley over 6 years ago in reply to ichliebedich
    I believe you must interrupt Allegro from auto-loading your most recent save.
    Your file history seems to be stored in %HOME%\pcbenv\allegro.mru
    You can rename that temporarily and re-launch 17.4 to see if the problem is an issue with the *.brd file you are auto-loading.
    Or, navigate to that board file and rename it.
  • ichliebedich
    I think it was related with firewall ! some ports related with SPB17.4 were blocked by firewall ...! ( it worked after formatting PC )
    but I still don't understand real cause, it worked SPB 17.2 though
