  3. Partial Etch Length
  • Replies 7
  • Views 18361
Partial Etch Length
tmccann2020
tmccann2020 over 6 years ago
I am trying to measure the etch length of a trace, but only on part of it.
I click "Show measure" and then I select two ends of a trace or cline segments, but it selects the full Cline/Net and gives me the total etch length, where I am only interested in a segment.
  • steve
    steve over 6 years ago
    Look at the Find pane settings, turn all off except Cline Segs and see if that helps......
  • tmccann2020
    tmccann2020 over 6 years ago in reply to steve
    Yes, I have tried that. Once I select the ends of segments, the whole cline/net is highlighted.
  • RFinley
    RFinley over 6 years ago in reply to tmccann2020
    That sounds like you have Nets and CLines enabled in the find filter dialog.  Make sure everything is off except CLine segments.  What the find filter matches will flash as you hover over it with your mouse.
  • tmccann2020
    tmccann2020 over 6 years ago in reply to RFinley
    I have only the Cline segs option selected.
    You can see in the attached image: I click select segment vertex on the Via and then select segment vertex on the 2nd bend, but the whole cline from the via to the pad is selected, instead of the small section of etch I am interested in.
  • CadAce2K
    CadAce2K over 6 years ago in reply to tmccann2020
    Just click on a segment (one click), not the 2-vertex selection way.
