  3. Footprints for Small Polarized Capacitors
  • Replies 8
  • Views 21546
olebon
olebon over 6 years ago
Sorry about an elementary question, I am still in process of transition from PADS where such questions never arise.
I have a problem with adding polarized caps.  For example, I need to use a 0805 Tantalum 10uF. If I follow tutorials and and just drop in a 'C' from "discrete.lib" and then try to assign an existing footprint from "C:\Cadence\SPB_17.4\share\pcb\pcb_lib\symbols" all I can find to fit is a non-polarized "smc0805.dra". Trying to avoid  designing a new footprint I downloaded a cap from Ultralibrarian, but their footprint "F98-S_AVX"does not show any polarity either.
I am not really a PCB designer, but an embedded engineer and design not very professional prototype boards once per 6 months to be cleaned later. To fix the issue on my prototypes I simply add '+" to the silkscreen where it has to be in the actual footprint.
So my question is, what is the proper way to add '+' to 0805 or 0603 packages of polarized capacitors? Thanks!
  • steve
    steve over 6 years ago +1
    Use PCB Editor to open the filename.dra of an 0805 then use Add - Text, set the Options pane to Package Geometry / Silkscreen_Top, the relevant text size and then add a + in text and position where you…
  • steve
    steve over 6 years ago in reply to olebon +1
    take a look at:- https://www.parallel-systems.co.uk/wp-content/uploads/2020/02/SPB172_Footprints-Parsys.pdf the names follow the ipc naming convention.
  • steve
    Use PCB Editor to open the filename.dra of an 0805 then use Add - Text, set the Options pane to Package Geometry / Silkscreen_Top, the relevant text size and then add a + in text and position where you want this to go. I would then save the footprint as 0808_pol which saves a new filename.dra and filename.psm. Use this name for your pcb footprint going forward when you need a polarized cap.
  • olebon
    olebon over 6 years ago in reply to steve
    Thank you, Steve. It turns out that it is better to design a new footprint or redesign existing one. I just finished the Padstack editor tutorial and created my first SOIC8 for test. Really easy, as good as PADS.
    Now I have a different question. In the folder "C:\Cadence\SPB_17.4\share\pcb\pcb_lib\symbols" there are thousands of probably useful footprints with absolutely confusing names. Is there any guide on the naming convention? Instead of calling them with human readable "SOIC8" or "TQFP64" they prefer "dax2850x225062.dra". There should be a good reason for such strange naming.
  • steve
  • olebon
    This is exactly what I was looking for. Thank you very much.
  • olebon
    Now I am having another unexpected problem.
    I tried to follow your advice and created a custom library with a copy of 'C' and 'Cap POL' of Discrete.Lib . Assigning of 'SMC1206' to 'C' works fine, however if I assign SMCT3216 to Cap  POL following message pops up whenever I try to import netlist to PCB editor:
    ERROR(SPMHNI-196): Symbol 'SMCT3216' for device 'CAP POL_MY_0_SMCT3216_CAP POL_MY' has extra pin 'N'
    Even if I rename Cap POL pins '1' and '2'  to 'P' and 'N' the message does not disappear.
