  3. How to add soldermask to a PCB symbol?
  • Subscribers 167
  • Views 18090
olebon
olebon over 5 years ago
I have a number of downloaded parts which have correct top and bottom etch but no soldermask at all. First, I tried to use Z-copy to copy a pin shape (for a round through-hole) from etch to Package Geometry -> SoldermaskTop, however, it is impossible to copy or even select a shape, so I failed. Then I tried to edit the DRA file,  so I opened it in PCB editor and found that it is also impossible not even select any object, but even  see the right-click menu to select edit mode. If anybody knows the secret, please help! Thanks.
  • steve
    steve over 5 years ago +1
    Try Tools - Padstack - Modify Design Padstack then left click on the pin and right click click Edit. Padstack Editor will be launched. Go to the Design Layers tab and get the size of the pad (select and…
  • redwire
    redwire over 5 years ago
    Remember that adding a soldermask geometry to a symbol *removes* soldermask as it is a negative operation.
    For a padstack the same thing applies.  The soldermask layer removes from around the pin.
    You should not see any solderrmask on any parts in general. What are you exactly trying to do?
  • steve
    Try Tools - Padstack - Modify Design Padstack then left click on the pin and right click click Edit. Padstack Editor will be launched. Go to the Design Layers tab and get the size of the pad (select and use CTRL+C) then go to the Mask Layers tab and select Soldermask_Top (and or Bottom) and use CTRL+V so that this is now defined, You may also need to repeat for Pastemask_Top and or Bottom. Once complete Use File Save to save the padstack to the library but use File - Update to Design and Exit to fix it in the board / dra file.
  • olebon
    olebon over 5 years ago in reply to steve
    Thank you very much, you are the best!!!!
  • olidajin
    olidajin over 5 years ago in reply to steve
    [deleted]
