  3. Converting Via into DXF marked circle
  • Replies 19
  • Views 21275
KARTHIK RANGARAJ
KARTHIK RANGARAJ over 5 years ago
I received DXF file from mechanical team. In DXF has some circle. I have to place via in that circle location.  Is there is any way to place via automatically  in the provided circle location.
  • masamasa
    masamasa over 5 years ago in reply to KARTHIK RANGARAJ
    u can try these to see if this works or not.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000002JjbZEAS&pageName=ArticleContent
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000007MXnYEAW&pageName=ArticleContent
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MoU0UAK&pageName=ArticleContent
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000091CjzUAE&pageName=ArticleContent
  • masamasa
    masamasa over 5 years ago in reply to masamasa
    if nothing works, u might want to place vias manually after figuring out the xy location of the vias on the dxf file as it has got only 30 vias.
  • KARTHIK RANGARAJ
    KARTHIK RANGARAJ over 5 years ago in reply to masamasa
    Thanks Masa. I believe  we need separate license > thanks let me try to do  in manuall. but i have 2000 vias Slight smile
  • masamasa
    after figuring out the xy locations, u may be able to place vias using this skill.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nbSNEAY&pageName=ArticleContent
