  3. QR Barcode
  • Replies 11
  • Subscribers 168
  • Views 19869
QR Barcode
Wild
Wild over 5 years ago
Hi Folks!
New request from the boss, they want to add QR Barcodes to our PCB's.  Did a little searching and I haven't found a solution that works well for 16.6.  Does anyone have ideas?
I can create them as a dxf and bring them in, but not all the shapes are filled in.  I can do this manually, be it's a PIA.
Thanks in advance,
Wild
  • masamasa
    masamasa over 5 years ago
    i usually create a gerber file for bar codes then import it.
    for importing dxf files, u need to convert lines to shapes.
    https://community.cadence.com/cadence_technology_forums/f/pcb-skill/7407/axlskill-function-to-convert-a-cline-to-a-shape
  • Wild
    Wild over 5 years ago in reply to masamasa
    TY for the reply.  I understand the dxf conversions and the steps that will need to be done.
    I prefer not to edit the gerbers, there always last minute changes that seem to be required after I create the artwork, I would rather do it in Allegro.
    There is a tool from FlowCAD, but it costs.....  My boss doesn't like to spend $
    The import using logo maker is not usable.
    Looks like I will need do the dxf in and creat filed shapes as needed.
    Many thanks,
    Wild
  • masamasa
    masamasa over 5 years ago in reply to Wild
    do u have a tool to convert a dxf file to a gerber file?
    if so, u can import the gerber file to ur allegro.
  • oldmouldy
    oldmouldy over 5 years ago in reply to Wild
    You could give this a try: https://www.mediafire.com/file/9m6lohjnnr1n01h/AllegroQRCodeGenerator172.zip/file
    Windows only. QR Code is traditionally dark dots and light gaps but silkscreen is light dots and dark gaps so options to "reverse" and add a border to simulate a "normal" image (either seems to be recognized though). This hasn't been tested in a good while so there may be issues now, security with later Windows 10 builds for example, that weren't apparent when this was last tested.
  • jatins
    jatins over 5 years ago in reply to oldmouldy
    I tried using the mentioned QR Code Generator and i am getting xxx.dra and xxx.bsm files as output.
    The dra file has Package Geometry> Silkscreen_Top as shown here:
    My question is how can i convert this into actual qr code that can be read by phone camera right away.
    TIA!
