  3. QR Barcode
  • Replies 11
  • Subscribers 168
  • Views 19870
QR Barcode
Wild
Wild over 5 years ago
Hi Folks!
New request from the boss, they want to add QR Barcodes to our PCB's.  Did a little searching and I haven't found a solution that works well for 16.6.  Does anyone have ideas?
I can create them as a dxf and bring them in, but not all the shapes are filled in.  I can do this manually, be it's a PIA.
Thanks in advance,
Wild
  • myil17
    myil17 over 4 years ago in reply to jatins
    Hi Jatins,
    Could you find solution to this? How could you locate the root directory for QR Code Generator?
    BR
  • oldmouldy
    oldmouldy over 4 years ago in reply to myil17
    The utility needs to know the "root" location of the Cadence SPB Installation, default is C:\Cadence\SPB_17.2 which is checked, but, if the Cadence SPB installation is in another folder, the Configure needs to be used to set the "root" folder location. (The utility adds tools\bin\allegro.exe to the "root" folder to locate the PCB Editor application to create the symbol from the generated script for the QR code)
  • myil17
    myil17 over 4 years ago in reply to oldmouldy
    It can generate the .dra file but now complaining about license and deleting the generated files right after.
  • oldmouldy
    The utility generates a script, SCR, file and then starts PCB Editor to create a DRA file from that script, starting from a copy of a "template" DRA file. If there isn't a license available for PCB Editor then the DRA and BSM files won't be created and the "template" DRA file and associated working files will be deleted from the target folder.
  • myil17
    I have a license for EDM launcher where I normally use pcb editor and schematics. Is it possible to run it through EDM?
