  3. how to modify Step file height in Allegro PCB?
  • Replies 7
  • Subscribers 167
  • Views 17058
ichliebedich
ichliebedich over 5 years ago
Hi All
I have this step file below
but I want to modify the height of the package of highlighted by red
How can I change the height in Allegro / OrCAD PCB ?
regard
  • CadAce2K
    CadAce2K over 5 years ago
    edit/properties on the PLACE_BOUND_TOP or BOTTOM in the layout (on the footprint) and set a Max_Comp_Height to the shape.
  • CadAce2K
    It's easy  to get STEP files from the internet nowdays. And easy to use them in the 'Stepper'. Check out www.snapeda.com or www.ultralibrarian.com  Many, many parts out there.
  • steve
    steve over 5 years ago
    So If you don't map a step model the tools use the place_bound_top or _bottom shape. If these don't specify a height value the tools use the Default Symbol Height value. To modify this in the board file go to Setup - Design Parameters - Design tab and adjust this value to something reasonable, but the recommendation is to map a step mode since so many are available nowadays.
  • Wild
    Wild over 5 years ago in reply to CadAce2K
    These are great spots to get 3D Models and there are also others great sites such as:
    grabcad.com
    www.3dcontentcentral.com
    Note many vendors will proved the models on request.
    BTW a great tool for changing the file type from formats such as IGES or other formats is FreeCad.
    Another note of interest for understanding the height constraint is www.parallel-systems.co.uk there have a great write up on the this feature (PBC19) user guide.  This team is the best!
  • ichliebedich
    ichliebedich over 5 years ago in reply to CadAce2K
    what if I map the STEP file on footprint, Does user not able to modify the height value?
