  3. how to modify Step file height in Allegro PCB?
  • Replies 7
  • Subscribers 167
  • Views 17059
ichliebedich
ichliebedich over 5 years ago
Hi All
I have this step file below
but I want to modify the height of the package of highlighted by red
How can I change the height in Allegro / OrCAD PCB ?
regard
  • jc teyssier
    jc teyssier over 5 years ago in reply to ichliebedich
    You will still get the heigth defined on package geometry/plce_boud_top. Mapped step file wil not overide it. But while exporting brd step file you will get the symbol step definition.
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to ichliebedich
    You cannot modify the height of the actual 3D step model. You can only vary the block height. Goto setup - areas - select package height. Under the options window, you can set the height of the component provided the place-bound subclass is added to the component.
