  3. DRC Driven Same Net Spacing Clearance Working for Through...
  • Subscribers 166
  • Views 13180
DRC Driven Same Net Spacing Clearance Working for Through Pins but Not SMD Pins
l3hrbonini
l3hrbonini over 5 years ago
As stated in the title, DRC driven clearance appears not to work for SMD pins, but does work for through-pins.  I can add properties for clearance and type to the SMD pin and that will work just fine, but relying on the constraint and global parameters just results in a full contact connect.  I've looked through global parameters and constraint manager and everything looks correct to me, and is the same for both through and SMD pins.  Is there somewhere else I should be looking?
  • excellon1
    excellon1 over 5 years ago
    You might want to verify that the actual DRC mode for Same Net Spacing is enabled. On the cm tool bar click on analyze > Analysis Modes to verify that.
  • l3hrbonini
    l3hrbonini over 5 years ago in reply to excellon1
    Ok, checked that.  Everything under Same Net Spacing "SMD Pin to" is set to "On".  I've worked with OrCAD for a number of years and haven't seen this particular behavior before.
  • steve
    steve over 5 years ago
    Is this for a Dynamic Shape? If so look at Shape - Global Dynamic Params - Thermal Relief Connects and see what is set there. Also make sure on Void Controls tab the values are set to DRC which then follow the Constraint Manager rules. If this isn't it maybe a few screenshots to explain what's not working.
