  3. Padstack Editor 17.4 problem : Value must be greater than...
  • Replies 16
  • Subscribers 166
  • Views 20847
Padstack Editor 17.4 problem : Value must be greater than 0 [SOLVED]
alaphilippe
alaphilippe over 5 years ago
Hello !
I have a big problem when creating a padstack using the Padstack Editor 17.4
In the "drill" tab, I cannot enter any numeric data without having the error message: "Value must be greater than 0"
This problem does not appear in version 17.2  padstack editor
For  SMD pad, I have the same problem in configuring the dimensions.
My Cadence version is up to date
Anyone have a solution?
  • alaphilippe
    alaphilippe over 5 years ago in reply to excellon1
    I also tested as an administrator, as well as different modes of compatibility.
    And I have this problem on 3 PCs (same cadence version same W10)
  • steve
    steve over 5 years ago in reply to alaphilippe
    Can you open and save a padstack from the installation folder C:\Cadence\SPB_17.4\share\pcb\pcb_lib\symbols ?
  • excellon1
    excellon1 over 5 years ago in reply to alaphilippe
    In your picture the padstack editor looks to have an IP-Address specified at the top of the window. Are you doing things locally or via a network ?.
  • alaphilippe
    The problem is solved after reinstalling CADENCE
    But after reboot WIndows, same problem with padstack editor....
  • alaphilippe
    Cadence is installed locally, but database is on network (NAS)
