  3. Defining Board size
  • Subscribers 166
  • Views 13449
Defining Board size
Mikky
Mikky over 5 years ago
Hello, I want to have a specific size for my PCB but I am a bit confused as to how to achieve this. Do I do a board outline under board geometry or draw a line for cut out on my board?
THANKS
  • RFinley
    RFinley over 5 years ago +1
    We stopped needing that more than 20 years ago. Only feature that really uses it is 3D rendering. Just define the outline polygon on the Design outline layer
  • RFinley
  • Mikky
    Mikky over 5 years ago in reply to RFinley
    Right. Got it. Thanks
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to Mikky
    You can use the board wizard where the X,Y dimensions can be specified. It works if the board is standard rectangular/ square board only not on irregular shaped boards.
