  3. Test Point
  • Subscribers 167
  • Views 14542
Test Point
Danilo Pichilli
Danilo Pichilli over 5 years ago
Hi, I would like to insert test points on the bottom side of my pcb. But when I go to generate the gerber of the soldermask bottom I have to add the layer: "Via Class / soldermask bottom" to make sure that it does not have the soldermask on my final pcb in the test points. Unfortunately this causes me the absence of the soldermask also on the vias .. is there an alternative way to solve this problem? (I specify that the test point must be smd)
thanks
  • excellon1
    excellon1 over 5 years ago +1
    Hi try Via class / Soldermask_Bottom Pin /Soldermask_Bottom. That should work
  • RFinley
    RFinley over 5 years ago in reply to Danilo Pichilli +1
    Testpoints are not netlist items from the schematic. Every software I've used since Scicards, testpoints are vias with properties added that protect them.
  • Wild
    Wild over 5 years ago in reply to Danilo Pichilli +1
    I assumed that, but clarity is needed, others that read these forums may not understand what you are requesting. If you google test points, a wiki page shows up: https://en.wikipedia.org/wiki/Test_point…
  • Wild
    So I added this comment for the community to understand.
