  3. Placing decoupling caps on the bottom side under the BG...
  • Views 14378
Placing decoupling caps on the bottom side under the BGA
Peter Cerbone
Peter Cerbone over 5 years ago
I'm looking for a skill that would determine the BGA to be either 1mm or .8mm and then place the caps according.
I trying to speed up the process of placing these caps. The majority of boards I work on may have 6-8 BGAs on them.
Is this possible?
Peter
  • DE202408202727
    DE202408202727 over 5 years ago
    Certainly this would be possible. Ease of implementation would depend on whether the decoupling caps are easily identifiable (are they in the same room as the BGA) and consistency of the rules around where you want the caps placed. Pitch can be determined several ways.
    This is one way: pin1DBID = car(symDBID ->pins), pitch = apply('min, mapcar(lambda((pin2DBID), axlDistance(pin1DBID ->xy, pin2DBID ->xy)), cdr(symDBID ->pins)))
  • Peter Cerbone
    Peter Cerbone over 5 years ago in reply to DE202408202727
    Hi eDave,
    I don't think the caps are in the same room as the BGA. I was hoping I can window select the caps I want to place under the BGA.
    Peter
  • RFinley
    RFinley over 5 years ago
    I think it will pay off if you look at EMA-EDA's Circuitspace plugin for Allegro/Orcad.   Works with HDL and CIS.
    I have built a CS library of circuit blocks I can accurately replicate even if it's a partial match.  Accommodates netlist differences between blocks (missing termination resistors are ignored.)
    When block placement is complete, apply template copper including shapes, CLINES and vias even if the stackup is different from the template.
    Allows you to rotate circuit blocks at odd angles and flip to the back side of the board.  And, crossprobe between an intelligent PDF for placement.
    www.ema-eda.com/.../circuitspace
  • Peter Cerbone
    Peter Cerbone over 5 years ago in reply to RFinley
    Hi RFinley,
    Thanks for the advice I'll look into it.
    -Peter
