  3. Change default units in Padstack Editor
  • Views 12690
GForte
GForte over 5 years ago
Is it possible to change the default units in the Padstack Editor to be something different than mils?
Many thanks
  • excellon1
    excellon1 over 5 years ago +1
    Sure, When you open the padstack editor click on the "Start Tab", down in the bottom left of the padstack editor window you should see "Units" with a drop down selection so as to change the units. Depending…
  • excellon1
    Sure,
    Depending on the units you design your board in it may be an advantage to have your padstack editor always use those units, for example mm instead of mils. You can change this by opening the PCB Editor and then going to
    "Setup User Preferences"
    In that user preferences window do a search for "Units" A number of results will be returned from the search. You should see a "Pad_Designer_New_Units" option. Select the units you want, hit apply and then ok.
    When the padstack editor is now used it will use those default units you set.
    Hope this helps .
  • GForte
    GForte over 5 years ago in reply to excellon1
    Thank you, that is exactly what I was looking for. It works great!
