  3. Allegro NC Drill and NC Route Integer.decimal format not...
  • Replies 13
  • Views 20291
Allegro NC Drill and NC Route Integer.decimal format not exported in Gerber
frank mpbc
frank mpbc over 5 years ago
In Allegro 17.2 2016, how do I force the INTEGER.DECIMAL format commands into the .drl and .rou exported outputs?
Let me explain in more detail.
When I export gerber files for copper, solder mask and etc, I see in the files the Gerber  FS command which give the X and Y Integer.Decimal format. See
https://electronics.stackexchange.com/questions/197584/how-do-you-know-what-resolution-a-gerber-file-has
For the NC drill and NC route, I put in the NC parameters a check in the Enhanced Excellon format with leading zero suppression. See picture. Is the leading zero suppression bad?
When I export the files and look in the .drl and .rou, I do not see the format anywhere. When I import into a free viewer such as Viewmate, it makes a guess. I see the NC route scaled 10x too large.
Frank
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    the variable setting nc_drill_export_coordinate_format worked before Hotfix_SPB17.40.018:
    INCH,00.00000
    but not since:
    INCH
    the CCR status is 'Planned'
  • frank mpbc
    frank mpbc over 5 years ago in reply to DavidJHutchins
    Thanks for your response.
    How do I put this variables setting?
  • frank mpbc
    frank mpbc over 5 years ago in reply to frank mpbc
    I like to add I am using metric.
  • DavidJHutchins
    In 17.4
    Setup>User Preferences...
    Manufacture>drilling
  • frank mpbc
    I have both 17.4 and 17.2. It works real good in 17.4. Thank you so much!
