  3. Allegro NC Drill and NC Route Integer.decimal format not...
  • Replies 13
  • Views 20292
Allegro NC Drill and NC Route Integer.decimal format not exported in Gerber
frank mpbc
frank mpbc over 5 years ago
In Allegro 17.2 2016, how do I force the INTEGER.DECIMAL format commands into the .drl and .rou exported outputs?
Let me explain in more detail.
When I export gerber files for copper, solder mask and etc, I see in the files the Gerber  FS command which give the X and Y Integer.Decimal format. See
https://electronics.stackexchange.com/questions/197584/how-do-you-know-what-resolution-a-gerber-file-has
For the NC drill and NC route, I put in the NC parameters a check in the Enhanced Excellon format with leading zero suppression. See picture. Is the leading zero suppression bad?
When I export the files and look in the .drl and .rou, I do not see the format anywhere. When I import into a free viewer such as Viewmate, it makes a guess. I see the NC route scaled 10x too large.
Frank
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    Stopped working with Hotfix_SPB17.40.018, still doesn't work with Hotfix_SPB17.40.020
  • EnottonE
    EnottonE over 5 years ago
    Try using a format where the decimal point is not 5 but 4 characters, i.e. for example 3.4 or 2.4 (depending on the size of the board). This helped us, before that, when using the 3.5 or 2.5 format with the drilling card, there were often problems, then the holes would disperse very much in the scale, then decrease in a heap.
  • DavidJHutchins
     Hotfix_SPB17.40.022 fixed this in the .rou files, but not the .drl files Disappointed
    D:\SPB_Data\xxx\yyy>cat *drl *rou | grep INCH
    INCH
    INCH,00.00000
  • frank mpbc
    frank mpbc over 5 years ago in reply to EnottonE
    Hello EnottonE,
    It looks like that the viewmate viewer doesn't get better when using 4 characters instead of 5. I found the Viewmate viewer that allows to override its guess. Thanks for your input.
  • frank mpbc
    frank mpbc over 5 years ago in reply to frank mpbc
    I found the Viewmate viewer [[setting]] that allows to override its guess.
