  3. Allegro NC Drill and NC Route Integer.decimal format not...
  • Replies 13
  • Views 20298
Allegro NC Drill and NC Route Integer.decimal format not exported in Gerber
frank mpbc
frank mpbc over 5 years ago
In Allegro 17.2 2016, how do I force the INTEGER.DECIMAL format commands into the .drl and .rou exported outputs?
Let me explain in more detail.
When I export gerber files for copper, solder mask and etc, I see in the files the Gerber  FS command which give the X and Y Integer.Decimal format. See
https://electronics.stackexchange.com/questions/197584/how-do-you-know-what-resolution-a-gerber-file-has
For the NC drill and NC route, I put in the NC parameters a check in the Enhanced Excellon format with leading zero suppression. See picture. Is the leading zero suppression bad?
When I export the files and look in the .drl and .rou, I do not see the format anywhere. When I import into a free viewer such as Viewmate, it makes a guess. I see the NC route scaled 10x too large.
Frank
  • frank mpbc
    frank mpbc over 5 years ago in reply to DavidJHutchins
    In my 17.4 exportations, I see in both my .drl and .rou files the correct format command of
    METRIC,TZ,000.00000
    . Viewmate is detecting properly the format with the 17.4 exportations. It is guessing bad with the 17.2 exportations,
    Is there a way to see which Hotfix is applied? I am not sure if I have the Hotfix 17.40.007 or the 17.400.013.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    in Allegro the Help>About will show the current settings
    Also, the 1st line of the journal file shows the version info:
    D:\SPB_Data\xxx\yyy>head -1 allegro.jrl
    \t (00:00:01) allegro 17.4 S022 Windows SPB 64-bit Edition
  • DavidJHutchins
    Cadence support notified me that if I enable the drill option "Optimize drill head travel" the coordinate info will be written into the drl file, which may be why it works for you...
