  3. How to set a funckey to submenu item in Allegro / PCB designer...
  • Views 13162
How to set a funckey to submenu item in Allegro / PCB designer ?
nutron
nutron over 5 years ago
I am trying to set up a funckey in the env file to point to a submenu item.
I am trying to assign the "d" key to point to the "Setup>Areas>package Height"  submenu item.
I did this in the env file : funckey d "Package Height"   , but PCB designer can not find it.
How can i make a keyboard shortcut to a submenu item ?
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I'm not sure you can create a funckey definition point to a submenu
    however the actual command you want the funckey to run is 'package_height'
    funckey d "package_height"
  • nutron
    nutron over 5 years ago in reply to DavidJHutchins
    Thank you , that worked.
    I didn't put in the underscore.
    The odd thing is that i created another shortcut this way : funckey p "shape edit boundary" without underscores and it worked. So i assumed it would be the same for the package height function.
  • DavidJHutchins
    DavidJHutchins over 5 years ago in reply to nutron
    Most of the Allegro commands use spaces in the command names, but a few use _ instead
    I always use 'helpcmd' to see what the actual command name is before referencing it in an alias or menu entry...
  • nutron
    Fantastic. I was looking for a list of commands.
    I found a document by cadence that is giving a few examples of funckey commands , but i haven't found anything that explains the command syntax for more complex keystrokes.
    Do you know by chance if there is such a tutorial or document existing?
