  3. PAD AND SOLDERMASK CHAMFER
  • State Suggested Answer
  • Answers 1
  • Views 11839
intoi
intoi over 4 years ago
Hi Everyone,
This newbie (me) need some help with Pad stack editor. I have a chamfer corner on my pad stack that measure 0.4101mm in length.
What Corner Chamfer Value would that exactly translate in Pad stack editor? I tried putting 0.4101 and then placed the pad in my symbol then exported a dxf file to see if it will come out as 0.4101 but it did not.
This is part of my pad drawing where the chamfer is.
Any input will be greatly appreciated.
Thanks a lot!
  • soll
    soll over 4 years ago +1 suggested
    Hi! If you want a chamfer with a size of x, you must input "x/ √ 2" in the corner chamfer size. In you case, that will be 0.2899. You can see a chamfer as the diagonal of a square :)
  • soll
    0 soll over 4 years ago
    Hi!
    If you want a chamfer with a size of x, you must input "x/√2" in the corner chamfer size. In you case, that will be 0.2899.
  • intoi
    0 intoi over 4 years ago in reply to soll
    Hi Soll, that helps a lot. Dumb me coz math was never really my thing.
    Thank you again.
