  3. Display issues on Allegro Viewer 17.4 using Virtualbox
  • State Suggested Answer
  • Answers 1
  • Views 12287
Leandro Heck
Leandro Heck over 4 years ago
Hello folks,
I am using Allegro Viewer 17.4 on a Virtualbox (Version 6.1.32_Ubuntu r149290) with Windows 11 as the guest OS.
For some reason Allegro Viewer is not working properly. It is not displaying the canvas/board/desing area completely. Something happens that half of the screen, inside of the program, is always black/dark, and only half or less is visible.
Does Allegro have any limitation regarding the screen resolution or something that I could check to prevent this from happening?
Did you have experienced the same issue?
Do you know how to fix this or maybe something that I could try to improve?
Thank you all.
Best regards.
  • Leandro Heck
    0 Leandro Heck over 4 years ago
    Ah, I found out that OpenGL is the culprit.
    Then the Allegro Viewer has a version (which is also installed by default) that is "Allegro Physical Viewer 17.4 (no OpenGL)" that does not have the related issue. This solves my issue here.
  • Leandro Heck
    0 Leandro Heck over 4 years ago in reply to Leandro Heck
    While this works with Allegro, it does not work with OrCAD since it does not have a version without OpenGL.
    In this case, how do I fix it for OrCAD too?
