  3. Is there a way to fix the target net in propagation delay...
  • Views 13897
Is there a way to fix the target net in propagation delay?
avant
avant over 4 years ago
I set clock nets as targets in relative propagation delay work sheet.
While reviewing, the target nets changed. Is there a way to fix the target?
  • steve
    0 steve over 4 years ago
    Yes - In the Delta:Tolerance cell for the net right click - Set as Target
  • avant
    0 avant over 4 years ago in reply to steve
    Yes, I set the target, but somehow the target net changed to another net.
    This happened on four busses that I had set the clocks as the target nets.
  • steve
    0 steve over 4 years ago in reply to avant
    Could be hotfix related so make sure you are running the latest version, 17.4-2019 S030 or 17.2-2016 S083
  • avant
    Thanks! I'll give that a go.
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to steve
    The role of delta & tolerance is still confusing. When delta is set 0, the results will be different, when it set to nil the results are different. Aren't zero & nil value play same role ? It would be great if anyone could brief out delta & tolerance role.
