  3. Procedure in the while loop
  • State Suggested Answer
  • Replies 11
  • Answers 2
  • Views 15061
JuriV
JuriV over 3 years ago
Hi everybody,
I want to execute a procedure until the Escape key will be pressed.
Example:
continue = t
while( continue
        ....execute procedure
if (cancel or escape) then
continue = nil
);end while
How could I Do that?
  • JuriV
    JuriV over 3 years ago in reply to JuriV +1 suggested
    I tested the function "axlEnterEvent" again. By Mouse CLICK the Message "This is a Test CLICK" appears. If Escape (CANCEL) is pressed - "End of Loop". But how the DONE could be used? You mentioned the…
  • B Bruekers
    B Bruekers over 3 years ago in reply to JuriV +1 suggested
    You must bind the SKILL function to a command line function : axlCmdRegister( "EnterEvent" 'EnterEvent ?cmdType "interactive") Doing so and starting the command from the command line results in: scriptmode…
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago
    From the 'Cadence SKILL Language User Guide' documentation:
    Use the prog function and the return function to exit early from a for loop. This example
    finds the first odd integer less than or equal to 10.
    prog( ( )
    for( i 0 10
    when( oddp( i )
    return( i )
    ) ; when
    ) ; for
    ) ; prog
    However, I don't know of any way of detecting a key press ( such as 'escape' ) since Allegro doesn't appear to support bindkeys
  • B Bruekers
    0 B Bruekers over 3 years ago
    What are you planning  to do in the loop?
    If it is some user interaction with selection then use the axlEnterEvent() .
    Otherwise look at the axlCancelOff, axlCancelOn, axlCancelTest  functions.
  • JuriV
    0 JuriV over 3 years ago in reply to B Bruekers
    Hi B Bruekers,
    I have a code to align the vias (vertical or horizonthal). I want to align the VIAS inside of the while loop. The VIAs are selected using
    dbid_vias = axlGetSelSet(axlSingleSelectBox()). For example I select three VIAs to aligne them, then next four VIAs, then next ten Vias and so on.
    This function should work until Escape (or another termination) is pressed, which means "No more VIAs to aligned".
    I hope this explained a function.
    Best regards
    Juri
  • B Bruekers
    0 B Bruekers over 3 years ago in reply to JuriV
    Then you need to use axlEnterEvent().  So something like this:
    ;start "myselection" from the command line of Allegro
    axlCmdRegister( "myselection" 'SelectonLoop  ?cmdType "interactive")
    procedure( SelectonLoop()
        let( (loop msg event StartXY)
             axlSetFindFilter( ?enabled '("noall" "vias") ?onButtons "vias")
            msg= "Select vias"
            loop = t
            while( loop
                event = axlEnterEvent(list('PICK 'PICK_EXTEND 'PICK_TOGGLE 'STARTDRAG 'STARTDRAG_EXTEND 'STARTDRAG_TOGGLE 'STOPDRAG 'STOPDRAG_EXTEND 'STOPDRAG_TOGGLE ) msg nil)
                caseq(event->type
                    (PICK                  when(axlAddSelectPoint(event->xy), doSomethingWithSelection()))
                    (PICK_EXTEND     when(axlAddSelectPoint(event->xy), doSomethingWithSelection()))
                    (PICK_TOGGLE     when(axlSubSelectPoint(event->xy), doSomethingWithSelection()))
                    (STARTDRAG
                        axlAddSimpleRbandDynamics(event->xySnap "box" ?var_point 0-car(event->xySnap):0-cadr(event->xySnap))
                        StartXY= event->xy
                    ((STARTDRAG_EXTEND STARTDRAG_TOGGLE)
                        StartXY= event->xy
                    (STOPDRAG
                        axlClearDynamics()
                        when(axlAddSelectBox(list(StartXY event->xy))
                        StartXY = 0
                    (STOPDRAG_EXTEND     axlClearDynamics(), when(axlAddSelectBox(list(StartXY event->xy)), doSomethingWithSelection()),    StartXY=0 )
                    (STOPDRAG_TOGGLE    axlClearDynamics(), when(axlSubSelectBox(list(StartXY event->xy)), doSomethingWithSelection()),    StartXY=0 )
                    (DONE
                        loop = nil
                    (CANCEL
                        loop = nil
    procedure( doSomethingWithSelection()
        let( (selectedItems)
            when(selectedItems = axlGetSelSet()
                pp(selectedItems)
  • JuriV
    OK, Thank you.
    I used such function for PICK, but not for CANCEL or DONE. Are CANCEL and DONE like Escape or the popup for RMB with Cancel and Done functions should be define?
    Best regards
    Juri
