  3. Procedure in the while loop
  • State Suggested Answer
  • Replies 11
  • Answers 2
  • Views 15062
JuriV
JuriV over 3 years ago
Hi everybody,
I want to execute a procedure until the Escape key will be pressed.
Example:
continue = t
while( continue
        ....execute procedure
if (cancel or escape) then
continue = nil
);end while
How could I Do that?
  • JuriV
    JuriV over 3 years ago in reply to JuriV +1 suggested
    I tested the function "axlEnterEvent" again. By Mouse CLICK the Message "This is a Test CLICK" appears. If Escape (CANCEL) is pressed - "End of Loop". But how the DONE could be used? You mentioned the…
  • B Bruekers
    B Bruekers over 3 years ago in reply to JuriV +1 suggested
    You must bind the SKILL function to a command line function : axlCmdRegister( "EnterEvent" 'EnterEvent ?cmdType "interactive") Doing so and starting the command from the command line results in: scriptmode…
  • B Bruekers
    0 B Bruekers over 3 years ago in reply to JuriV
    The DONE and CANCEL are by default defined in the RMB as well through the general user interface (like F2 key binding)
    So, any DONE or CANCEL event is caught by the axlEnterEvent() and ends up in the DONE/CANCEL case statement.
    You can define a own RMB menu with extra functionality, like 'oops', align H, align V, etc.  Each RMB item can call a function to deal with the operation.
    You need to implement the Oops functionality with axlDBTransactionStart(), axlDBTransactionMark(), axlDBTransactionOops() and axlDBTransactionCommit().
    A small tip, before any axlDBTransactionMark() you need to do a axlClearSelSet(). Otherwise an 'oops' event will cause an issue where previous selected items are 'highlighted' and cannot be selected again.
  • JuriV
    0 JuriV over 3 years ago in reply to B Bruekers
    Thank you very much, I will try it
  • JuriV
    0 JuriV over 3 years ago in reply to JuriV
    I tested the function "axlEnterEvent" again. By Mouse CLICK the Message "This is a Test CLICK" appears. If Escape (CANCEL) is pressed - "End of Loop". But how the DONE could be used? You mentioned the CANCEL and DONE should be connected to the RMB automaticaly.
    Hier is the code:
    procedure( EnterEvent()
    let(( loop event)
    eventMask = '( PICK CANCEL DONE)
    loop = t
    while( loop
         event = axlEnterEvent(eventMask, nil, t)
         case(event -> type
         ('PICK
        printf("This is a Test CLICK")
         ); end PICK
     ('CANCEL
         printf("End of Loop")
         loop=nil
     );end CANCEL
     ('DONE
         loop=nil
     );end DONE
        );end while
      );end case
     );end let
    );end procedure
  • B Bruekers
    scriptmode +e
    EnterEvent
    EnterEvent
    prepopup 143.484 -183.964
    pop Done
    End of Loop DONE
    generaledit
    EnterEvent
    EnterEvent
    prepopup 107.355 -201.512
    pop Cancel
    End of Loop CANCEL
    generaledit
    (I've added a Done and Cancel to the printf())
  • JuriV
    Ok, Thanks.
    This works in Command Mode only, not in the SKILL Mode. That is my mistake.
