  3. Procedure in the while loop
  • State Suggested Answer
  • Replies 11
  • Answers 2
  • Views 15071
JuriV
JuriV over 3 years ago
Hi everybody,
I want to execute a procedure until the Escape key will be pressed.
Example:
continue = t
while( continue
        ....execute procedure
if (cancel or escape) then
continue = nil
);end while
How could I Do that?
  • JuriV
    JuriV over 3 years ago in reply to JuriV +1 suggested
    I tested the function "axlEnterEvent" again. By Mouse CLICK the Message "This is a Test CLICK" appears. If Escape (CANCEL) is pressed - "End of Loop". But how the DONE could be used? You mentioned the…
  • B Bruekers
    B Bruekers over 3 years ago in reply to JuriV +1 suggested
    You must bind the SKILL function to a command line function : axlCmdRegister( "EnterEvent" 'EnterEvent ?cmdType "interactive") Doing so and starting the command from the command line results in: scriptmode…
  • JuriV
    0 JuriV over 3 years ago in reply to B Bruekers
    Do you know how is possible to change the CHECKBOX in the FORM during the while loop?
    Like in your Example, I put in the STOPDRAG section:
    procedure "Do something 1" if CHECKBOX in the FORM is checked
    procedure "Do something 2" if CHECKBOX in the FORM is NOT checked
    In my code this not works. I have to interrupt (e.g. with axlCancelOn()) the WHILE loop to check/or uncheck the CHECKBOX. Do you know if this works without  interruption?
    JuriV
