  3. Using Cadence license with firewall
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 12605
Ken X
Ken X over 3 years ago
I am using Cadence 17.2. The license server is in the lab. For IT infrastructure update, office and lab were settled in defferent LANs and there is a firewall between them.  In lab, everything works well. I opened TCP port 3000 and 5280 in firewall, but neither capture nor PCB editor can get license when working in office LAN. PCB designer report error LMF-13016: License call failed.
Is there other port should be opened in firewall?
  • oldmouldy
    oldmouldy over 3 years ago +1 suggested
    If you use the Cadence License Manager installer, 5280 and 3000 are the default ports that get configured but, it might be worth checking in the log file for the license manager that they are the assigned…
  • RFinley
    0 RFinley over 3 years ago
    Flexera uses by default, port 27000 thru 27009 for signalling.  But I haven't tried setting up a firewall yet.
    In my battle between Firewalla and Comcast Xfinity.  DHCP depends on capturing the MAC address of your router.
    If you change your router, well...  don't.   Write down your router MAC address before your box dies so you can clone it.
  • oldmouldy
    0 oldmouldy over 3 years ago
    If you use the Cadence License Manager installer, 5280 and 3000 are the default ports that get configured but, it might be worth checking in the log file for the license manager that they are the assigned ports since "any" could have been selected. If the license server is being found by name, check that the DNS is resolving to the correct IP address for the license server and that the network routing will route that IP address to the correct network. As a temporary measure, drop the firewall packet filtering and see if you get a license.
