  3. Allow overlapping soldermask
  • State Suggested Answer
  • Replies 11
  • Answers 1
  • Subscribers 167
  • Views 16892
SOT23
SOT23 over 3 years ago
I have some issues with the soldermask constraint set available in Constraint Manager > Analysis Mode.
At the moment, my constraints are set like this :
And I have ticked the option Allow overlapping soldermask in Analysis Mode > Design for Fabrication.
Still, I have this kind of errors showing up :
Info on the errors says :
Class: DRC ERROR CLASS
  Subclass:        SOLDERMASK_TOP
  Origin xy:       (28.5588 37.5420)
  Constraint:      Symbol Soldermask to Pad Soldermask Spacing
  Constraint Set:  SOLDERMASK_SPACING
  Constraint Type: DESIGN
  Constraint value: 0.1 MM
  Actual value:     0 MM
  Element type:    SHAPE
  Class:           PACKAGE GEOMETRY
  RefDes:          MA8
  Element type:    VIA
  Class:           VIA CLASS
  origin-xy:    (28.4088 36.9420)
  Part of net:       GND
  Connected pins:      1 ( TOP )
  Padstack name:   V65H30
  Usage:           Through_via
  CIRCLE_DRILL  :  0.3000   Plated
The via is covered by 1:1 soldermask circle. As you can see, the soldermask shape from the symbol and the soldermask from the via are overlapping entirely. Still, Allegro throws an error for each via... Why is this happening ? As I understand it, the "Allow overlapping soldermask" should... Allow soldermask to overlap, right ? :p
I don't want to remove the "Soldermask to pad and cline" DRC option because it allows me to spot places where soldermask could be uncovering a cline. But I want Allegro to allow soldermask that completly overlap. Is there a way to do that ?
Thank you in advance !!
PS : As a side note, the Info text from the "Allow overlapping soldermask" option is missing in the Analysis Mode box.
  • avant
    0 avant over 3 years ago
    If the symbol has a soldermask shape, perhaps you can edit the vias and remove the soldermask. Edit the via, save as new name, replace.
  • SOT23
    0 SOT23 over 3 years ago in reply to avant
    Hello, thank you for answering !
    I could do that, or I could just waive the DRC errors, but I would prefer to find a way to set the constrain right so that I don't have to work around what seems like a misconfiguration.
  • steve
    0 steve over 3 years ago in reply to SOT23
    Try looking at setting the soldermask rules in Constraint Manager - Design for Fabrication settings. Currently there are two methods, one in Constraint Manager and one in Setup - Constraints - Modes. The overlap is only valid for the CM method.
  • SOT23
    0 SOT23 over 3 years ago in reply to steve
    Hello Steve and thank you for answering.
    Are you talking about this option ?
    If yes, it is ticked, but it doesn't seem to change anything. Should it remove these DRC ? To my understanding, it should, but maybe I am  wrong ?
  • steve
    I don't think the DRC is going to do what you think it does. If you hover over the "i" at the end of the name you should see the info on what it does:-
    I don't believe there is a DRC check that will solve your issue so you can try and add a property to the PCB Footprint itself which would stop the DRC. Open the filename.dra then Edit - Properties, in the Find Pane click on the Find by Name dropdown and choose Drawing then look for nodrc_sym_shape_soldermask and nodrc_sym_pin_soldermask and add both those properties (Apply and OK). Then save the dra file. Then refresh this in the board and see if that resolves your issue.
