  3. DRC for shape minimum width
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 9659
JanMironkiewicz
JanMironkiewicz over 3 years ago
is it possible to setup DRC which will point necks in dynamic shapes? example below:
  • steve
    steve over 3 years ago in reply to avant +1 suggested
    There is a Shape - Check command that checks based on the minimum aperture value. More relevant to Static Shapes because a Dynamic shape would void out the area smaller.
  • avant
    0 avant over 3 years ago
    Under shape parameters, you can set the minimum aperture gap value. This should void out shapes smaller than the value.
    I don't know if there is a DRC setting for minimum shape neck width.
  • steve
    0 steve over 3 years ago in reply to avant
