  3. Generating Allegro report with data from external file
  • State Verified Answer
  • Views 10866
Dave413
Dave413 over 3 years ago
Hello Cadence community,
When choosing any of the reports in Allegro PCB design -> tools -> quick reports, a separate window pops up with a report table usually containing hotlinks to relevant locations on the board.
Is there a way to go from an excel spreadsheet into an Allegro Report popup window with location hotlinks?
Please refer to image below for illustration.
P.S I have some Skill programming experience so am also open to coding suggestions.
David Nguyen
  • oldmouldy
    oldmouldy over 3 years ago +1 verified
    There is nothing "magic" about this. The PCB Editor File Viewer, File>File Viewer, will read "any" text file and turn "any" entries with a format of <space>(<number> <number>)<space>, like " (10.0 10.0…
  • oldmouldy
    +1 oldmouldy over 3 years ago
    There is nothing "magic" about this. The PCB Editor File Viewer, File>File Viewer, will read "any" text file and turn "any" entries with a format of <space>(<number> <number>)<space>, like " (10.0 10.0) ", into links to navigate the board. The numbers are taken as database units. The default type for the File Viewer is LOG files but TXT / ALL files can be selected.
  • Dave413
    0 Dave413 over 3 years ago in reply to oldmouldy
    Thank you Mouldy, this is exactly what I was looking for!
