  3. Find Degassing Void overlap in adjacent layer?
  • State Verified Answer
  • Subscribers 166
  • Views 11978
Yuva09
Yuva09 over 3 years ago
Hi ,
I want to check the only Degassing void overlap in adjacent layers
Is there any skill file is available for checking this? or in Allegro having any options Please let me know
Thanks in advance
  • masamasa
    masamasa over 3 years ago +3 verified
    u may have "shape degassing" on the manudacture menu. if not, u can type "degas" on the command line. then the following degassing window shows up. u can avoid overlaps on the adjacent layers…
  • masamasa
    masamasa over 3 years ago in reply to ra1124 +1
    u can avoid placing degassing voids over manyally placed voids by turning on "no void overlap." so i usually place degassing voids at the very last step of my designing processes. i agree that we…
  • masamasa
    masamasa over 3 years ago in reply to Schulz Jordan +1
    to avoid air trapped on your boards, u need degassing volds/holes.
  • masamasa
    +1 masamasa over 3 years ago
    u can avoid overlaps on the adjacent layers by checking "no void overlap."
    there is also another command that checks if the degassing voids u created are overlapped or not by "assembly rules checker" on the manufacture menu.
    u can type "assemrules standard" on the command line if this is not on the menu.
    on the assembly design rule checks, u can check and run the degassing void overlap on design/miscellaneous menu.
    if u do not want any degassing voids above or below the critical clines, u can select the clines and check "degas_no void" on the property so that the degassing voids can avoid those clines.
    • Vote Up +3 Vote Down
  • ra1124
    0 ra1124 over 3 years ago in reply to masamasa
    Good summary.  Would be nice to have a way to apply "degas" property to a manually made void so this would also be flagged by the check tool.
  • masamasa
    0 masamasa over 3 years ago in reply to ra1124
    i agree that we need some kind of checking tools.
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to masamasa
    Why we need degas ?
  • masamasa
    0 masamasa over 3 years ago in reply to Schulz Jordan
